Help urgent!
tarekwm
132
im going to buy a video card now just need to ask wat is the best video card for a 1280X1024 res screen to play high end games for next couple of years note that i have a 4g ram ddr3 an intel 2500 cpu and an h67 board since i despise oc
blade061188
655
1280x1024 is not a very high resolution. Neither a 560 Ti nor a 6870 will be working very hard at that resolution.
However, if you are going to update your monitor to a widescreen, say 1920x1080, then you'd really see your graphics card put to good use.
Are you looking to max out all settings (Textures, AA, Etc), or just run with good detail?
