Help very important
hypervyper
54
I just bought a prebuilt gaming pc and I cant install my gigabyte motherboard bios drivers disc because when I try to install it says xpress does not support this version of windows
Motherboard- Gigabyte 78LMT-USB3
OS- Windows 10 64 bit
dont ever use the disc, they are usually outdated. go directly to the site
it depends on which revision you have of that mobo. should be able to be found on the box or printed on the pcb somewhere.
http://www.gigabyte.com/products/product-page.aspx?pid=5195#dl
just takes a little googling
