Archived from groups: microsoft.public.games.ageofkings (
More info?)
Hi Alex,
Look at step 2 in my post below. Good luck!
"Alex" <Alex@discussions.microsoft.com> wrote in message news:0B730C1F-F8C6-43D3-BF71-C00D158EB6CA@microsoft.com...
> no i cant play offline fine either it lags also, no virus/spyware, and about
> this ventilation issue what do you suppose i am to do about it?
> "Jimmy S." wrote:
>> Hi Alex,
>> Can you play fine offline? If yes, check your system for virus or
>> adware issues, otherwise you might have a case ventilation issue.
>> Cheers, Windows XP MVP Shell / User
>> Jimmy S.
http://mvp.support.microsoft.com
>> Game FAQs:
;gms]http://support.microsoft.com/default.aspx?scid=FH;[LN];gms
>> Visit my MSN Zone.com and Gaming Help Site:
http://mvps.org/nibblesnbits
>> MS Assisted Support:
http://support.microsoft.com/select/?target=assistance
>> My advice is donated "AS IS" without warranty; nor do I confer any rights.
>> _________________________________________________________
>> "Alex" <Alex@discussions.microsoft.com> wrote in message news:0C0CC256-68C4-4AA1-AED0-3C567FEDF2C9@microsoft.com...
>> | hi plz help me cus my age of kings the conqs. uses up a lot of cpu usage and
>> | makes it lag horribly, also when i use the zone that lags real bad too so
>> | please help me thx, and 1 last thing that came to mind whenever i play age it
>> | exits a lot when i dont have a little minature fan facing the box while its
>> | open and i had just bought a brand new fan for my cpu so i dont no its just
>> | really annoying and i want to play but these 3 things arent helping me thanks
Hardware issues can cause freezing, black screens and other
errors. Also, your drivers should always be kept up to date.
Try the following steps one at a time to try and resolve the issue.
I hope this helps. Please post back if you have any questions!
1. Update DirectX and your Chipset, Sound, &Video Drivers:
For all Video / DirectX / Game and Hardware Issues, I have a
Checklist of Solutions at:
http://NibblesNbitsVideo.tk
2. Dust your fans, vents and components using a 1/4" paintbrush
and a hose vacuum. Use compressed air for hard to reach places.
Set a housefan to blow cold air into your case to expose an over-
heating issue.. If it works add more fans or replace defective ones.
Use this Motherboard Monitor Utility:
http://mbm.livewiredev.com
3. A faulty power supply can cause STOP errors, random reboots,
and black screen lockups. One way to test for that is to check the
wattage sticker on your power supply and then calculate your need
http://www.jscustompcs.com/power_supply/ (Min. 350 for gaming)
4. Test your RAM using:
http://oca.microsoft.com/en/windiag.asp
Jimmy S.
Game FAQs:
Visit my Zone.com / Gaming Helpsite:
http://nibblesnbits.tk or Call / Contact
MS Support at:
http://support.microsoft.com/default.aspx?scid=sz;en-us;top
