HELP!!!: Water cooling for Gigabyte GeForce GTX 770 WindForce 3X OC 2GB GDDR5 (GV-N770OC-2GD)
WinshesteR
146
Hi,
I've been trying to find a water cooling sistem for my Gigabyte GeForce GTX 770 WindForce 3X OC 2GB GDDR5 (GV-N770OC-2GD). Can anyone please help me with this?
So, there isn't really a need other than to say you did? This is fine, just be prepared to figure out how you need to accomplish this if you really want to do it. If your card isn't Nvidia reference PCB (which it seems it might not be, based on your findings above), then your only option would be a universal GPU block and RAMsinks for the remainder of the components to be cooled (which will still need airflow).
Is this only to cool the GPU? No CPU?
There isn't likely going to be a 'system' or a kit that accomplishes cooling just the card you have. Why do you feel you need watercooling on this card? I have an EVGA GTX 770 and I do watercool it, but just curious as to your reasons/needs?
well... i will be plasing some more cards on it and a better cpu...
but trully i just want it to have a nice look thats the main reason
