So, let me get started. I'm working on a project with a full water cool loop inside, i've been looking around and i've found the perfect rads I want. When I say rads I mean i'll be running a loop with 2 different sized radiators, a Alphacool NexXxoS UT60 Full Copper 480mm and a Alphacool NexXxoS UT60 Full Copper 360mm. I want the CPU, MOBO and GPU/s to be cooled. My only problem is I want to stick to a colour scheme of white, I know the bitspower fittings come in white so i'm leaning on going towards those. I don't want to use soft tubing as i've had many problems with that in the past, I'm going to use rigid tubing.
Now that's clear here is my problem, I don't know what fittings to use for the loop. And if anyone could suggest a good pump, not pump and res combo that'll be great. Keep in mind this build is huge, i'm building my PC into a desk.
Thanks guys!
Thanks guys!
