[SOLVED] [HELP] What do you think about my build?
Dominik27
4
Hey, This is my first build and just wanted to post it here to get your opinion guys. I plan to use it mainly for gaming and photo editing. Obviously it also needs to look cool - I like white so I decided to go with it. I took Ryzen into consideration but i5 is better value for the money atm.
https://de.pcpartpicker.com/list/FRgKj2
Thanks in advance!
That is a very nice built. But if your looking for a full white build, then you should pick a white gpu and a white motherboard. there's a white gtx 1660 super from galax and there's also a white b460m pro4 from asrock. both are colored white, so if your looking for a full white build you should go and pick those.
