Help! What will i sort to power on my HP motherboard
Oct 24, 2018
I need help about my hp motherboard
Its from prebuild hp compaq dc5800
I want to ask what will i sort to power it on the front panel is different from other motherboards.
It says "PB/LED P5" with pins like this:
OOOOO
OOXOO
The motherboard and case were designed to work together, you need to post a picture of the pins with clear markings that can be seen or a link to a picture of your motherboard. You are missing a bit of details, sounds like you are trying to move this motherboard into another case? Does that case have separate case wires or are they together with a larger plastic connection? You can also get some add-on power switches if you can't find a way to wire up your case that are pretty much two cables attached to the power button that will hang out of the case.
