Help! WHEA_UNCORRECTABLE_ERROR but its not driver nor hardware related!
Brammetje
11
Hello everybody,
I have recently build a new system and since beginning i have the issue that my screen freezes and reboots.
I have tried replacing everything (CPU, Motherboard, PSU, GPU, booting without HDD, booting without SSD, another RAM) with a replacement and with everything the problemen still persists...
Could it be that it is a faulty Windows (i have one USB with Windows on it maybe there went something wrong with putting Windows on it??)
Here are the dump files: https://www.dropbox.com/s/odt7shs5q3fcfs9/Dumpfiles.zip?dl=0
PS my pc specs are:
XFX Radeon R9 290
2x 4GB Crucial RAM
FX-8320E
ASRock 980DE3/U3S3
Kingston SSD and a Samsung 1TB HDD
PC Power & Cooling 750W Quad
Hey. Could you follow these steps please:
1. Press "Windows + R" at the same time
2. Enter "control wuaucpl.cpl" (without speech marks) followed by enter
3. Select "Scan for Updates"
4. Install all updates including optional ones
5. Restart your PC into the normal desktop
6. Restart your PC into Safe Mode
7. Press "Windows"
8. Enter "cmd" (without the speech marks)
9. Right click "Command Prompt"
10. Select "Run as Administrator"
11. Enter "sfc /scannow" (without the speech marks) followed by enter
12. Let the scan complete
Let me know how this goes.
Hello and thanks for your reply!
I have updated (two updates couldnt update with code 800B0100 and code 8007065E)
And i have ran sfc /scannow and there where no errors.
Hope you can help me further...
EDIT: Now using windows readiness tool to fix the problem that it cannot update :)
EDIT2: It rebooted while fixing 🙁
Try using the tool again but close ALL programs, including the ones in the taskbar.
I have tried the program again he said it was installed succesfull but the updates can still not install... I am going to try putting Windows on another USB stick an then chose the option "Upgrade" could that work?
The person where i got the product key from did it for me, but you can do it yourself with at the official windows site. I can't do it anymore because they need a product key that is not in use. And mine is in use... So i need to borrow a dvd from somebody.
