Help! When i press the power button the computer only starts for a split second then turns off.
PopCornScott
12
When i press my power button the cpu and rear fan go on for a split second then it shuts down? I was going to clean my pc and i saw a good spot to put some cables so i took out the power cable out of the mobo (the 2pin one) and moved it and put it back. After that the computer wont start. It started after 6/7 tries and i thought it fixed itself so i turned it off and when i tried turning it on again same problem D: Please help (oh and the parts are almost brand new and i had touched the case many times so i didn't zap it)
PopCornScott
12
My specs are
CPU: Intel i5 4570 3.2GH.z
GPU: Msi GTX 770 Twin Frozr gaming editon
MOBO: Msi z87 G45 Gaming
Case: CM storm trooper
PSU: Cooler Master V700
Ram 2x4 G.skill sniper 1600mhz
Cpu Cooler: Cooler Master 212 Evo
I Have had these parts for about a month and had the fully built pc for 2 weeks and nothing unusual has happend
PopCornScott
12
nope i tested, but today the pc wont even turn on? I forgot to mention i saw a little light flashing on the motherboard yesterday aswell :p But is there something that is broken like the mobo or psu? I dont know if the mobo is broken because how else would the cpu fan go on for a split second if its broken?
Jan 8, 2014
158
7
I've had this before, my second build, the problem (for me at least) was power supply, it roasted to a crisp and ahd to buy it again, not sure about yours, could be the power supply too, how old is that PSU is?
legokill101
2,020
199
um ok thats important that means likely a bad psu but just to be sure i need you to first insure that all cables are completly pluged in and then take out one stick fo ram try to boot if it doesnet put it back and and remove the other and then remove the gpu and try and boot off the intagrated gpu
lazy69
test the ram take out both then turn on then install each module of ram 1 by 1 turn on again arfter testing each one to see if it boots up next test graffix card by remooving and turning on the fans should spin and stay on test before you suspect the motherboard and processer
BardeMk
I can see that the problem is solved, but i want to share my solution.
The symptoms were as described, and the problem was faulty power button.
Regards
PMFTOTC
78
I recently have the same problem.
what do you mean but a faulty power buttion?
BardeMk
The power button was keeping the contact on. So when it was pushed it was maintaining the contact and was force shutting the PC.
Solution was new (cheap) power button.
Regards
PMFTOTC
78
Oh! tks!
I will check my later, How can I test this? clearly I don't have another power button...
PMFTOTC
78
hey, how did you test whether the power button is broken.
I have opened up my case, the button was connected to the motherboard.
How to test the functionality of the button?
tks.
