[SOLVED] (help) which case ?
Dec 26, 2018
I'm planing to get a new case , and I settled on two cases :
1- lian li lancool one
2-Cooler Master MasterBox TD500
and I don't know which one should I get . so what should I get
Dec 26, 2018
well there is a discount on the lian li lancool one . and it's cheaper than the cooler master , the lian li lancool one comes with a temperd glass . and the cooler master one comes with an acrylic side panel . but the air flow in the cooler master is better. so what should I do ?
