Help Whit Laptop Choice from 4 same specs please.
NEVERDIE
29
Hi all, after 3 months of looking still cant find a good laptop.
Looking for a thin , aluminium one.
I seen some of the Dell one's and i somehow hate how plastic they are and thick base looks like cheap empty laptops.
What i do: well now i have an Optiplex 745 whit a dual core CPU and 3 GB ram and a 9600gt whit low power consumption, im not a gamer but i do some minor gaming like, Call of Duty, and such shooters but mostly on low and medium resolution.
And a little bit of web and graphic design whit fireworks and Photoshop.
I will use and work on this laptop at least minimum of 6 hours a day.
So yes this will be a desktop replacement, but it will do some traveling to costumers, no problem whit big laptops for me as im not a p...y 😀
Thanks for the comments.
Expectations are, I7-2630QM. at least 4 Gb Ram DDR3 and HDD not matters as i have a big SSD.
So i have seen 4 laptops and would like to see what the comunity says.
First: XPS 17 L702x (not really prefered cause of low build quality, Thick base, empty plastic feal)
2nd generation Intel® Core™ i7-2630QM processor 2.00 GHz with Turbo Boost 2.0 up to 2.90 GHz
17.3"(44 cm) HD+ WLED True-Life (1600x900) with 2.0 Mega Pixel Integrated Camera
6144MB (1x2GB, 1x4GB) 1333MHz DDR3 Dual Channel SDRAM
DVD+/-RW (DVD, CD read and write)
1TB (7,200rpm) Serial ATA Dual HDD - (2x500GB)
9-cell 90Whr Lithium Ion battery
3GB NVIDIA® GeForce® GT 555M Graphics Card
Intel® Centrino® Advanced-N 6230 (2x2 b/g/n+ Bluetooth Combo Card)
Internal DVB-T TvTuner
FOR £909.00 inc VAT.
SECOND: VOSTRO 3750
Intel® Core™ i7-2630QM 2.0GHz
17.3 inch High Definition LED Display (1600 X 900) with anti-glare
6144MB 1333MHz Dual Channel DDR3 SDRAM [1x4096 + 1x2048]
8X DVD+/-RW Drive including software
500GB (7,200rpm) Serial ATA Hard Drive
Primary 6-cell 48 WHr Lithium Ion battery
NVIDIA® Geforce™ GT 525M with 1GB VRAM
European Dell Wireless 1702 (802.11b/g/n) + Bluetooth
FOR £946.00 inc VAT.
THIRD: ASUS N73SV-TZ044V
Intel Core i7 2630QM (2.00GHz)
17.3" 16:9 Full HD (1920x1080) LED backlit
3 x 2GB DDR3 1333
Blu-Ray Combo
2 x 500GB S-ATA (5400RPM)
6 cells: 4400 mAh
NViDIA GeForce GT 540M 1 GB
Integrated IEEE 802.11 b/g/n Bluetooth v2.1+EDR
FOR £934.00 inc VAT.
FOURTH: HP Pavilion DV7
Intel Core i7 2630QM / 2 GHz
17.3" TFT 1600 x 900 ( WXGA++ ) HD+ BrightView
6 GB / 8 GB (max)
DVD±RW (±R DL) / DVD-RAM / BD-ROM
1 TB - Serial ATA-300 - 5400 rpm
6-cell Lithium Ion
AMD Radeon HD 6490M
FOR around £909.00 inc VAT.
OR MAYBE A MACBOOK PRO I7 SECOND HAND RUNNING WINDOWS 7???
Hi,
In my opinion I would go for the Asus, I've had nothing but Asus motherboard wise in my desktops, as have a lot of my friends and they make extremely good, reliable hardware. Plus it also has blu-ray and a much better resolution than the others. The RAM you can always upgrade yourself for not much extra and it's fairly easy to do. HP used to have a lot of problems with overheating - Not sure if they have improved in recent years but all the reviews I've seen of them haven't been particularly amazing, a lot of people sending theirs off for repairs...As for the Dells, My experience with Dell over the last few years has been that their laptop build quality has gradually gone down and their prices have gone up. I think they are now taking advantage of their much heard of name and logo like Apple.
just my 2 cents :)
I've been eying that ASUS for a month now, and it might be the one I get in a few paydays (it ain't cheap), and I've found nothing but positive reviews for it (beside the standard - the "\" key is in the wrong place, etc).
Now the "versions" of it that I'm looking at have a bit more power in them (3GB graphics memory, 2x 750GB 7200rpm drives, 12GB mem), but they are the same case and screen. But by all reports, it has good cooling and good design and a good screen.
