Okay, so here's the problem: for the longest time, I had my super sexy monitor for my audio output, but on my machine there was a crapload of static. It would affect everything, and it happened especially when I plugged it in the back of my machine. From the front end, it wasn't so bad, but it was still there. So, I thought maybe it was just because the speakers were really crappy. Then, I got new speakers for Christmas today. Tried it out, and the static is still there. Same issue, and these are brand new speakers so I know it cannot be the speakers.
So, I looked at this and this to hopefully try to eliminate the problem.
This is my question: these are the two options pretty much anywhere I can look on amazon; is there really any practical difference between these two? Also, does it reduce bass significantly in my speakers, do you think? These are my speakers.
Thanks,
dazinger
Thanks,
dazinger
