Hi all
I got the following parts and were wondering if they would be compatible with each other:
Please note that I have not written either HDD or the case, because I am sure that the case and the HDD is compatible with all these parts. Also the case is quite small so the motherboard has to be a micro-ATX.
Motherboard (Asus Prime B350M-E): https://www.newegg.com/Product/Product.aspx?Item=N82E16813119020&cm_re=ASUS_Prime_B350M-E-_-13-119-020-_-Product
GPU (Sapphire Radeon Nitro rx580 8GB): https://www.newegg.com/Product/Product.aspx?Item=9SIA6V660T4200&cm_re=sapphire_radeon_nitro%2b_rx_580_8gb-_-14-202-280-_-Product
CPU (AMD Ryzen 5 1600x): https://www.newegg.com/Product/Product.aspx?Item=N82E16819113434&cm_re=ryzen_5_1600x-_-19-113-434-_-Product
Cooler (Noctua NH-L9x65 SE): https://www.newegg.com/Product/Product.aspx?Item=9SIAADY5BC4478&cm_re=Noctua_NH-L9x65_SE-AM4_CPU_cooler-_-13C-0005-00113-_-Product
RAM (Kingston Value 16GB 288-Pin DDR4 SDRAM ECC): https://www.newegg.com/Product/Product.aspx?Item=9SIA24G57Z4548&cm_re=Kingston_Value_DDR4_2400MHz_16GB-_-20-242-203-_-Product
I also got a cheaper RAM stick, but it's only 8 GB (HyperX FURY DDR4 2400MHz 8GB): https://www.newegg.com/Product/Product.aspx?Item=N82E16820104679&cm_re=HyperX_FURY_DDR4_2400MHz_8GB-_-20-104-679-_-Product
Which one of these RAM should I buy? I want a cheap PC, so I can't afford to buy more expensive parts, than the ones I already wrote here. Are all these parts compatible with each other? Any help is appreciated!
Edit: I only bought the GPU, I haven't bought anything else yet.
Edit: I got a EVGA 650W PSU: https://www.newegg.com/Product/Product.aspx?Item=9SIA6ZP3R86304&cm_re=evga_650_gq-_-17-438-059-_-Product
