Help! Will this fit?
xixpoisonxix
Hi everyone,
I'm planning on getting the following, but I'm not sure if the sound card can fit in there since I am SLI-ing. Can anyone verify this for me? Thanks a bunch!
ASUS P6T Deluxe V2 LGA 1366 Intel X58 ATX Intel Motherboard - Retail
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.197399
2 x EVGA 896-P3-1170-AR GeForce GTX 275 896MB 448-bit DDR3 PCI Express 2.0 x16 HDCP Ready SLI Supported Video Card - Retail
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.197568
HT | OMEGA STRIKER 7.1 Channels PCI Interface Sound Card - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16829271001
foolycooly
702
You should be able to fit it without a problem...if you look at the pictures on newegg's website you can see that there are two PCIe slots between pciex16 slot 1 and slot 2. If it can't fit in one of the two because of the size of the two 275s, you might be able to run one of the cards in the third pcie_16x slot.
