Help! - Will this Radeon HD 7750 card work with my system?
According to the specifications sheet the 305W PSU's 12v rail combined is 264W/22 Amps.
(Spec sheet: http://www.dell.com/downloads/global/products/optix/en/opti_755_techspecs.pdf)
The suggested requirements for a 7750 system is 16 Amps on the 12v rail, so that seems fine. the only thing you have to worry about then is likely the dimensions of the card & it fitting in your case. So get the tape measure out & check them against it.
And the mini tower version that uses, 305W, which you say you have, has the correct PCI-E x16 interface.
(15) PCI Express x16 connector (SLOT1)
