Hello,
I'd appreciate help with the following.
My wireless network connection from my notebook pc has stopped working. It used to work and I haven't changed any setting. The situation is as follows.
The cable modem is connected to a wireless router whose IP address is 192.168.0.1 On the tablet pc, I have set a fixed IP address, 192.168.0.105 and netmask of 255.255.255.0 This used to work like a charm.
Now, after bootup, at the command prompt, "ipconfig" shows:
[code:1:df128ff210]
IP Address: 192.168.0.105
Subnet mask: 255.255.255.0
Default gateway: 192.168.0.1
[/code:1:df128ff210]
However, "ping 192.168.0.1" returms all failure.
The "Wireless Network Connection Status" window says:
[code:1:df128ff210]
Status: Connected
Network: MyNet
Duration: 00:20:17
Speed: 11.0 Mbps
Signal Strength: (all bars lit up)
However, in the "Activity" part of the window, it shows
[code:1:df128ff210]
Packets sent: 772
Packets received: 0
Other laptop (this one) continues to work perfectly with the same router.
What am I doing wrong?
What could be the problem?
How to fix it?
The only thing that I suspect is one of the auto updates from Microsoft might have messed something up.
If it matters, the pc is an Averatec C3500 and the router is a D-Link 2.4 GHz one.
Thanks
[code:1:df128ff210]
[code:1:df128ff210]
Status: Connected
Network: MyNet
Duration: 00:20:17
Speed: 11.0 Mbps
[code:1:df128ff210]
Packets sent: 772
Packets received: 0
How to fix it?
Thanks
