I am a bit confused, I got the Power and Reset, but the others don't quite match up.
I need to wire in "H.D.D LED" which is two slots connected together
I also need to wire in "Power Led" which is two slots but are separate. (One -, one +)
This makes sense to me however the F panel has the following pin spots:
+PLED-
+HD-
+PW-
-RES+
-CI+
+Speak-
+Pwr_Led-
I believe that the HDD LED goes into PLED
and Power Led goes into Pwr Led is this correct?
And if so, there are 3 pins for the pwr led, but only two slots on the wire, do I do left and right and skip the middle?
I appreciate any help
+PLED-
+HD-
+PW-
-RES+
-CI+
+Speak-
+Pwr_Led-
