[SOLVED] help with 2 nvme installs
arcticyuki
30
i just installed a new nvme (my other nvme is my boot drive) and now if i restart my pc it says no os found unless i press f11 and even then i select my boot drive says no os but if i select the new drive it boots. any help will be appreciated
pc specs:
i7 9700k
msi gaming edge ac z390
msi rtx 2060
corsair 3200 2x8gb
samsung 970 evo plus 250gb
gigabyte ssd 1tb
seagate barracuda 1tb
evga 600b
arcticyuki
30
Update your post to include full system hardware specs and OS.
Check the motherboard's User Guide/Manual to ensure that the nvmes are correctly installed and configured.
Pay attention to the SATA ports being used.
i did check the manual and says it should work in that config but i just decided to move the sata cable to a different port and now it boots properly and a bit faster
