I have a 3570k sitting on an Asus p8z77-v LE. It's also sat on an msi mpower z77, so I know it's not a mobo issue. Currently it's at 4.3GHz at 1.114v . It's always been at 4.3GHz. It will not do 4.4GHz even at 1.45v on either board, although my i7-3770K had no issues at 4.9GHz.
It's not the vcore as such. You could probably lower vcore considerably since Ivy-Bridge will run at 4.2GHz on bios default settings.
There's more than just bumping the multiplier. There's LLC, there's eco settings that'll kill OC, there's quality of the psu, ability of the mobo, and above all there's the silicon lottery. While 4.2GHz or even my 4.3GHz is low on the totem pole, it's not unheard of. Intel only guarantees the cpu will run at rated speeds, that includes turbo, but any and all OC levels and ability are totally pot luck.
