Hello, This is the build I am going to order soon.
1.)Rosewill BLACKHAWK Gaming ATX Mid Tower Computer Case
2.)MSI Z77A-G41 LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
3.)EVGA 02G-P4-2660-KR GeForce GTX 660 2GB 192-bit GDDR5 PCI Express 3.0 x16 HDCP Ready SLI Support Video Card
4.)RAIDMAX HYBRID 2 RX-530SS 530W ATX12V V2.2/ EPS12V SLI Ready CrossFire Ready Modular Power Supply, New Version with Build-in LED Fan On/Off Switch
5.)Intel Core i5-3570K Ivy Bridge 3.4GHz (3.8GHz Turbo) LGA 1155 77W Quad-Core Desktop Processor Intel HD Graphics 4000 BX80637I53570K
6.)ADATA Premier Pro SP900 ASP900S3-64GM-C 2.5" 64GB SATA III MLC Internal Solid State Drive (SSD)
7.)G.SKILL Ripjaws Series 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model F3-12800CL9D-8GBRL
8.)Seagate ST310005N1A1AS-RK 1TB 7200 RPM SATA 6.0Gb/s 3.5" Internal Hard Drive
9.)LITE-ON DVD Burner - Bulk Black SATA Model iHAS124-04 - OEM
10.)Rosewill RNX-N250PC2 (RNWD-12001) IEEE 802.11b/g/n, PCI, Wireless-N Adapter (2T2R) Up to 300Mbps Data Rates, 64/128 bit WEP, complies with WPA/WPA2 standard (TKIP/AES), IEEE 802.1X
I was wondering about the motherboard, as i could get a b75 for cheaper, but I was thinking about using my ssd as a cache, which you cant do on a b75, only a z77. I was also wondering if I should go for the radeon 7850 instead of the gtx 660. Also, will this wireless card work well? (it is only 20 dollars) thanks
