R redfinger Honorable Apr 28, 2013 43 0 10,540 Apr 24, 2015 #1 I can get a 2nd cheap 760. I am wondering two things, Is it worth it? (It will cost around 70Pounds) and also I have a 600 watt PSU, bronze rated from corsair, will this suffice? Thanks
Solution RobCrezz Apr 24, 2015 Yeah if you play at 1080p and you can get it for a good price, then performance boost is good. Your PSU is good enough. Check your motherboard supports SLI first though.
RobCrezz Expert Ambassador Mar 14, 2013 19,077 99 75,190 Apr 24, 2015 Solution #2 Yeah if you play at 1080p and you can get it for a good price, then performance boost is good. Your PSU is good enough. Check your motherboard supports SLI first though. Upvote 0 Downvote Solution
