I am looking for advice on my build for graphic design (Krita and Blender). My budget is 900-1250EUR.
The build: https://de.pcpartpicker.com/list/TLrdyk
1.I think I want mATX, I do not want a big case, but if there is a smaller ATX option, then why not ?
2.If you can make this a little bit cheaper and/or better, it would be great.
3.I am deciding between this mobo and MSI B550 Mortar.
4.I need a thermal paste for CPU cooler, which one is recommended ?
5.I definitely need some cheap case fans.
6.I also want a monitor, I was thinking about Philips 326E8FJSB, it is 31.5'' full hd, but if there is a cheaper and/or better option like 1440p, I'm down.
7.Can you recommend a budget keyboard and mouse ?
