Hi everyone,
I'm trying to build a simple circuit, but need some help to make sure I'm doing it right.
Basically I need to make a wire heat up when I turn the circuit on. My plan is to use a 6v lantern battery, controlled by a simple switch and thin insulated wires with crocodile clips. If I join the circuit up, with each end attached to one end of a thin, uninsulated copper wire, will the copper wire heat up when I turn on the switch?
Thanks ahead of time
