Help with a few FM's (Bloodsport, Fortune & Glory, Collect..
G
Guest
Guest
Archived from groups: alt.games.thief-dark-project (More info?)
In Bloodsport, I thought I had done everything, but the objective to
"ransack the brothers supply room" remains unchecked. Where is this? I
already got into the room with all the crates that you can bash open or
throw against the wall to get the contents from inside. Is something else
the store room?
In Fortune & Glory, where the heck is the mask? I've done everything else,
but am missing the mask.
In Collectors Greed, I seem to have gone everywhere I can, yet I don't have
any objectives checked. Is there a walkthrough for this?
- Adam
> the store room?
> - Adam
In Bloodsport there may be one little trinket that's lying on the floor
that you missed. This happened to me and when I went back in I found
what I had missed. It's pretty easy to miss something small, especially
since throwing crates agains the wall can fling stuff all over the
place. I've even had stuff go partially through a wall to where you can
barely see it. And if you didn't do it, you need to break into all of
the crates, including the one with the nasty little surprise in it.
"Just Another Mook" <lmarc11@qwest.net> wrote in message
news:n_q1d.24$DT4.62732@news.uswest.net...
>> else the store room?
>> else, but am missing the mask.
>> have any objectives checked. Is there a walkthrough for this?
>> - Adam
> that you missed. This happened to me and when I went back in I found what
> I had missed. It's pretty easy to miss something small, especially since
> throwing crates agains the wall can fling stuff all over the place. I've
> even had stuff go partially through a wall to where you can barely see it.
> And if you didn't do it, you need to break into all of the crates,
Ah, that's it. Once I found the spiders, I reloaded and didn't open that
crate.
I'll go back and do that.
- Adam
"AgentAlbert" <agentalbert2001@hotmail.com> wrote in message
news:2qmsloF10loliU1@uni-berlin.de...
>>> - Adam
>> since throwing crates agains the wall can fling stuff all over the place.
>> I've even had stuff go partially through a wall to where you can barely
>> see it. And if you didn't do it, you need to break into all of the
> crate.
> - Adam
That did the trick. It was actually sort of fun, throwing the spiders in
the flooded room so they all drowned, and then throwing the explosive box in
that little room with the four tough bastard guards.
But where do I go to "get out of there"? How do I escape to finish the
mission?
- Adam
>>>>- Adam
>>crate.
>>- Adam
> mission?
> - Adam
It's been awhile since I played this one but if I remenber correctly,
when I accomplished everything on the list the mission ended. I think
the last thing that I did was to kill the guy behind it all. I don't
remember what his name was but he did seem to be a lying bastard that
was in need of getting stomped. And I was happy to do it. He had it
coming and I gave it to him. I would have put his head on a pike but I
couldn't find a pike lying around to put it on. There were sticks but I
think a pike would have looked much better.
news:0ns1d.266$DT4.67544@news.uswest.net...
>>>>>I already got into the room with all the crates that you can bash open
>>>>>or throw against the wall to get the contents from inside. Is
>>>>>something else the store room?
>>>>>- Adam
>>>crate.
>>>- Adam
>> in that little room with the four tough bastard guards.
>> mission?
>> - Adam
> It's been awhile since I played this one but if I remenber correctly, when
> I accomplished everything on the list the mission ended. I think the last
> thing that I did was to kill the guy behind it all. I don't remember what
> his name was but he did seem to be a lying bastard that was in need of
> getting stomped. And I was happy to do it. He had it coming and I gave
> it to him. I would have put his head on a pike but I couldn't find a pike
> lying around to put it on. There were sticks but I think a pike would
Ha! Well, he's already dead. I have an objective that says "get the hell
out of there!". Not sure where the exit is.
- Adam
In the Collector's Greed FM, how do I find the golden skull? There is what
seems to be a too obvious secret door in the bedroom of the big house, but I
can't locate a switch.
And where do I find the crate of basketballs? I found the note that has the
crate number for something that goes to the sports emporioum, but the only
numbered crate I found was the one with the spider-bot in it.
- Adam
news:2sdib2F1jthmkU1@uni-berlin.de...
what
I
the
> - Adam
In the bedroom, you need to check the doorframe very carefully. There's a
tiny switch down near the floor, on the right-hand side (I think). As for
the crate of basketballs, you probably haven't been in the right warehouse
yet. You can only get in by climbing over the wall as the entrance door is
broken. Go around behind the warehouse and you'll see an open shutter in the
building across from it. Put a rope arrow into the shutter and climb up.
From there you can jump to the top of the trees behind the warehouse, climb
onto the wall and then jump down inside.
Nightwalker
Remove *leavemealone* from email address
"Nightwalker" <nightwalkerfmleavemealone@shaw.ca> wrote in message
news:LZh8d.621811$gE.579006@pd7tw3no...
> what
>> but
> I
> the
>> only
>> - Adam
> the
> climb
Thanks. I had been in that warehouse, but I hadn't noticed the crate
numbers when picking them up. I was looking for one with a brass labeled
plate like the one in the other.
Found the switch, thanks for the pointer. I got 3 out of 4 secrets. There
appears to be a secret door in the side of the stone wall underneath the
warehouse. Do you know where the switch for that is?
- Adam
a
for
warehouse
is
> > the
> > climb
There
> - Adam
It's in the corner of the grassy area with trees that's above that stone
wall.
Nightwalker
