I just bought a Mass Cool CPU cooler (model 8WA741) with the intention of doing some overclocking later but after getting it installed my CPU is running at 38*C. The manual for this CPU says thats the max temp it should be at. It seemed to run around 33*C on stock cooling after being on all day and I would have thought this would bring the temp down some. Does anybody have any thoughts?
This is the first time I've ever tried to install a fan on a CPU so it's possible (likely
) I messed something up. I put the included heat paste on the CPU and installed the fan fairly tight but not so much I'd crack the Mobo. Is there any method to this process or is it simply apply the paste and install? Is it possible I put too much/not enough paste on or not tighten the fan enough for good heat transfer? I checked the fan and it's working just fine as well. Thanks in advance for the help.
Stretch
PS- does anybody know any good software for keeping tabs on your system? I've seen a few links in overclocking about them. I'd just like to keep an eye on my CPU temp more easily while trying to solve this problem.
Stretch
