Help with a new build!
DotDotBoom
57
Hi guys, I'm looking for a new build around the Fractal Design R4 or R5 case (black) and would like your advice if possible.
Approximate Purchase Date: This week
Budget Range: up-to £800 including the OS.
System Usage from Most to Least Important: surfing the internet, gaming and web design.
Are you buying a monitor: Yes (separate budget to the tower build)
Do you need to buy OS: Yes
Preferred Website(s) for Parts: No preference just wherever is the cheapest!
Location: City, State/Region, Country - Newcastle, England.
Parts Preferences: No preference just whatever is best for the price.
Overclocking: No
SLI or Crossfire: No
Your Monitor Resolution: Probably 1920 x 1080
Additional Comments: I would like a quiet, efficient PC which is great at multi-tasking but can also run games great aswell and as stated above built around the Fractal Design R4 or R5 case. The color scheme (I know it's a bit of a nightmare!) is black/white.
Thanks a lot. :)
The 4690 is not worth the extra cost, over a 4460 or even a 4590. Waste of money. A 120gb SSD is going to fill up quickly. Go with a 4460, and use the savings towards at least a 240gb SSD. Your build came out to 750 for me. Probably due to mail in rebates, that I turn off.
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor (£143.99 @ Amazon UK)
Motherboard: MSI H97 GAMING 3 ATX LGA1150 Motherboard (£76.99 @ Ebuyer)
Memory: G.Skill Ripjaws X Series 8GB (2 x 4GB) DDR3-1600 Memory (£50.77 @ Amazon UK)
Storage: Samsung 850 EVO-Series 250GB 2.5" Solid State Drive (£80.99 @ Amazon UK)
Storage:...
CPU: Intel Core i5-4460 3.2GHz Quad-Core Processor (£143.99 @ Novatech)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£38.34 @ Aria PC)
Video Card: MSI GeForce GTX 970 4GB Twin Frozr V Video Card (£274.98 @ Amazon UK)
Case: Fractal Design Define R4 (Black Pearl) ATX Mid Tower Case (£72.48 @ Aria PC)
Power Supply: XFX 550W 80+ Bronze Certified ATX Power Supply (£51.54 @ Aria PC)
Optical Drive: Lite-On iHAS124-14 DVD/CD Writer (£9.96 @ Aria PC)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) (£67.95 @ Ebuyer)
Total: £787.00
Generated by PCPartPicker 2015-04-20 16:43 BST+0100
EDIT This is a black/red theme - just noticed you wanted black/white... I'll see what i can change.
Here is a more black and white build, although i'd suggest going with the other one i listed:
Motherboard: MSI Z97S SLI Krait Edition ATX LGA1150 Motherboard (£89.99 @ Amazon UK)
Memory: Corsair XMS3 8GB (2 x 4GB) DDR3-1600 Memory (£55.84 @ CCL Computers)
Video Card: Zotac GeForce GTX 970 4GB Video Card (£255.00 @ Aria PC)
Total: £785.09
Generated by PCPartPicker 2015-04-20 16:39 BST+0100
R4 case with a black & white color scheme... This is a single GPU system and the XFX 450w PSU is plenty of power for a GPU upgrade to the GTX 970. If you want to go with an R9 290 / 290x, you will need to bump the PSU up to a 550w unit (from either XFX or Seasonic).
Motherboard: Gigabyte GA-H97M-HD3 Micro ATX LGA1150 Motherboard (£63.11 @ Dabs)
Memory: Mushkin Blackline 8GB (2 x 4GB) DDR3-1600 Memory (£56.90 @ CCL Computers)
Storage: Plextor M5S Series 256GB 2.5" Solid State Drive (£89.10 @ Scan.co.uk)
Video Card: EVGA GeForce GTX 960 2GB SuperSC ACX 2.0+ Video Card (£167.95 @ Scan.co.uk)
Power Supply: XFX ProSeries 450W 80+ Bronze Certified ATX Power Supply (£38.94 @ Aria PC)
Optical Drive: Samsung SH-224DB/BEBE DVD/CD Writer (£10.50 @ CCL Computers)
Operating System: Microsoft Windows 8.1 (OEM) (64-bit) (£75.54 @ Aria PC)
Total: £756.85
Memory: Corsair Vengeance 8GB (2 x 4GB) DDR3-1600 Memory (£54.96 @ Scan.co.uk)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive (£42.95 @ CCL Computers)
Video Card: EVGA GeForce GTX 970 4GB Superclocked ACX 2.0 Video Card (£275.94 @ Aria PC)
Case: Fractal Design Define R4 w/Window (Black Pearl) ATX Mid Tower Case (£81.26 @ CCL Computers)
Power Supply: XFX XTR 550W 80+ Gold Certified Fully-Modular ATX Power Supply (£69.70 @ Amazon UK)
Total: £807.45
Generated by PCPartPicker 2015-04-20 16:48 BST+0100
Ah right, to be honest thinking about it the only games I'm going to be playing regularly are the likes of CS:GO, Far Cry and Battlefield really, so I'm not sure if i'd be going overkill on the 970.
CS:GO is probably the game I play the most where as the others I play every now and then, I'm not too fussed on ultra settings, as long as I can run it fine I'm happy! :)
I'd suggest getting the best video card you can afford so you don't have to upgrade as soon, you will get much longer use out of a GTX 970 vs a GTX 960, and with your budget you can afford the 970. If you feel you would rather cut your budget back by about 100, then dropping to a r9 280/x or gtx 960 would work fine for you right now.
I'd get either one of these:
Video Card: XFX Radeon R9 280X 3GB Black Edition Double Dissipation Video Card (£174.17 @ Scan.co.uk)
Total: £174.17
Generated by PCPartPicker 2015-04-20 17:12 BST+0100
OR
Total: £167.95
Generated by PCPartPicker 2015-04-20 17:09 BST+0100
DOH! forgot this was the black/white theme thread! - edited the cards
White and black build.
Memory: Kingston Fury White Series 8GB (2 x 4GB) DDR3-1866 Memory (£49.99 @ Amazon UK)
Case: Fractal Design Define R4 w/Window (White) ATX Mid Tower Case (£79.30 @ CCL Computers)
Power Supply: XFX 750W 80+ Bronze Certified Semi-Modular ATX Power Supply (£61.76 @ More Computers)
Total: £793.91
Generated by PCPartPicker 2015-04-20 17:17 BST+0100
Thanks! I'm liking the idea of the XFX Radeon R9 280X at the minute because it keeps me under my budget for now and also sounds like a great card, but what sort of mobo should I get to pair up with the R9 280 and 4460? I have a decent idea on most stuff but motherboards just confuse me!
Sounds great! you know if this support wireless adapters? can't find anything on it.
Why the Z97 board with the 4460? No SLI, right?
That is exactly why I chose it. It is the only board that is decent, and matches the color scheme.
Latest posts
