Help with a PC build
RandomPerson54
First PC build, I don't really have much idea what i'm doing. Not looking for it to play anything too draining. I mostly play League of Legends, I would hope I could run 60 FPS constant on normal/high settings. I assume this would run that without that much problem but i'm looking for confirmation. The main concern is whether everything can fit smoothly into the case. Any recommendations for cheaper or better parts would be really appreciated! Nothing too expensive because I am on about a 600$ budget.
Motherboard: http://www.amazon.com/dp/B00EASJ2JI/ref=wl_it_dp_o_pC_S_ttl?_encoding=UTF8&colid=2583MJD0USY5M&coliid=I1I5T57WAHX5UM
Power: http://www.amazon.com/Thermaltake-Standard-Bronze-ATX12V-SP-550P/dp/B00BUM178Q/ref=sr_1_1?s=electronics&ie=UTF8&qid=1429907647&sr=1-1&keywords=Thermaltake+SMART+550W+80%2B+Bronze+Certified+ATX+Power+Supply
Case: http://www.amazon.com/dp/B005LIDU5S/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=2583MJD0USY5M&coliid=I1K5408QR48ZEJ&psc=1
Hard Drive: http://www.amazon.com/Western-Digital-Caviar-Cache-Desktop/dp/B00461G3MS/ref=sr_1_2?s=electronics&ie=UTF8&qid=1429916614&sr=1-2&keywords=Western+Digital+Caviar+Blue+250GB+3.5%22+7200RPM+Internal+Hard+Drive
Memory: http://www.amazon.com/dp/B006WAGGUK/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=2583MJD0USY5M&coliid=I3CZZ7U52HLE0D&psc=1
Graphics Card: http://www.amazon.com/dp/B00B3WTWXU/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=2583MJD0USY5M&coliid=I263C7RH4OD7M1
Processor: http://www.amazon.com/dp/B009O7YORK/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=2583MJD0USY5M&coliid=IL2F73I7L4OPC
I don't think the monitor affects anything but I might be wrong.
http://www.amazon.com/dp/B005LJWJSG/ref=wl_it_dp_o_pC_nS_ttl?_encoding=UTF8&colid=2583MJD0USY5M&coliid=I3FBW8HZ5342GI
Not that it really matters too much, but would this be at all portable? Would it damage it at all if I packed it say, in a suitcase? Not for a flight, just in the car.
I'm not planning on overclocking it. I haven't updated the battery yet as i'm not sure what to get. Any suggestions would be appreciated!
Edit: just updated the battery, heard from a friend it's better to get a little over what is required but that might just be for overclocking.
