I'd like some advice with a potential build i have been thinking about carrying out. I would like to know if these parts would be compatible with each other. The parts are as follow:
RAM: http://www.amazon.co.uk/HyperX-FURY-16-DDR4-Memory/dp/B013H7QH86/ref=pd_sim_147_41?ie=UTF8&dpID=41gNa1B%2BrSL&dpSrc=sims&preST=_AC_UL160_SR160%2C160_&refRID=0HSDFGVX501SJYF0RGQF
Power supply: http://www.amazon.co.uk/EVGA-600-Power-Supply-Unit/dp/B01127D0MY/ref=zg_bs_430514031_8
CPU:http://www.ebay.co.uk/itm/Intel-Core-i5-6600K-Processor-3-5GHz-up-to-3-9GHz-Quad-core-6MB-Cache-/262334517711?hash=item3d145b11cf:g:OGcAAOSwoydWiqAZ
CPU cooler: http://www.amazon.co.uk/Cooler-Master-RR-212E-16PK-R1-Performance-Universal/dp/B0068OI7T8/ref=zg_bs_430499031_2
Thermal compound: http://www.amazon.co.uk/Arctic-Cooling-MX-4-Thermal-Compound/dp/B0045JCFLY/ref=zg_bs_430499031_1
Motherboard: http://www.amazon.co.uk/Asus-Z170-Pro-Gaming-Motherboard/dp/B0126R3QPA/ref=sr_1_2?s=computers&ie=UTF8&qid=1458225249&sr=1-2&keywords=motherboard+z170
SSD: http://www.amazon.co.uk/dp/B00S9Q9VS4/ref=twister_B00TU5T4UI?_encoding=UTF8&psc=1
Graphics card: http://www.cclonline.com/product/199425/11242-13-20G/Graphics-Cards/Sapphire-Technology-Radeon-R9-380-Nitro-4GB-Overclocked-Graphics-Card-GDDR5-PCI-E-DVI/HDMI/DisplayPort-with-Dual-X-Cooling/VGA3359/
Case: https://www.asus.com/Chassis/TA88/specifications/
I'd also appreciate it if you could include in your comments whether I require any extra cables etc, as they are not included with a product.
Thanks in advance.
Thanks in advance.
