Question Help with a solidworks build
tempest464
17
hi guys i'm shopping for a new solidworks pc got my components list i'm wondering if everything is compatible and if i have a decent build overall budget is around 3k.
if you have any suggestions i'm all ears rather go air cooling tho over water cooling
cooler-
hermalright Peerless Assassin 120 CPU Air Cooler, 6 Heat Pipes, Dual 120mm TL-C12 PWM Fan, Aluminium Heatsink Cover, AGHP Technology, for AMD AM4 AM5/Intel LGA 1700/1150/1151/1200/2011/2066 (PA120)​
CASE-
Fractal Design Focus 2 Black ATX mATX Mini ITX Solid Mid
Tower Computer Case
MOBO-
GIGABYTE Z790 AORUS ELITE AX LGA 1700 Intel Z790 ATX Motherboard with DDR5, Quad M.2, PCIe 5.0, USB 3.2 Gen2X2 Type-C, Intel WiFi 6E, 2.5GbE LAN, Q-Flash Plus, PCIe EZ-Latch​
CPU-
Intel Core i9-14900K - Core i9 14th Gen 24-Core (8P+16E) LGA 1700 125W Intel UHD Graphics 770 Desktop Processor - Boxed - BX8071514900K​
GPU-
PNY RTX 2000 VCNRTX2000ADA-PB 16GB 128-bit GDDR6 PCI Express 4.0 x8 Workstation Video Card​
PSU-
CORSAIR RMx Shift White Series, RM750x Shift White, 750 Watt, 80 PLUS GOLD Certified, Fully Modular Power Supply​
RAM-
CORSAIR Vengeance 64GB (2 x 32GB) 288-Pin PC RAM DDR5 5600 (PC5 44800) XMP 3.0 AMD EXPO Desktop Memory Model CMK64GX5M2B5600Z40​
SSD-
Western Digital WD_BLACK SN770 M.2 2280 2TB PCIe Gen4 16GT/s, up to 4 Lanes Internal Solid State Drive (SSD) WDS200T3X0E​
You're advised to stylize your thread with info asked of in this thread;
including where you're located(if you're not located in the USA), what your preferred site for purchase is(since brand and parts availability can and will change with respect to region) and if you have any other preferences for your build that might pose a limitation.
At face value, the parts all look good. Punching them into PCPP might reveal any limitations, if there are any.
Moved thread from Components section to Systems section.
Latest posts
