Hi I have recently been experiencing a spotty/inconsistent internet connection on my PC. I will go to speed-test.com and it'll show anywhere from 750+ MBPS all the way down to 5-10 MBPS. I have tried resetting/rebooting the router, tried a newer cable and it seems that nothing has been a permanent fix. To clarify this is on a wired connection from my modem to my PC, and as far as I can tell it has to do with the wired connection. Upon doing a small 5 min investigation last night, when I un-plug the cable and turn on wifi my internet connection will be a consistent 250+ MBPS, and once I plug the cable back in it'll jump all over the place again. Any information would be greatly appreciated it. FYI I am kind of PC savvy but not network savvy, so may need a little further instructions then most on these forums. Thank you!!
Basic Equipment Info ---------------
PC -
Motherboard : Asus Z79-A WiFi
GPU: EVGA FTW 3090 TI
OS: windows 10
Modem: Net gear -
C7000v2 – Nighthawk AC1900
Firmware Version
V1.03.08
ISP: Comcast/Xfinity
Number of connected devices: 5
PC - wired
2 Phones - wifi
Xbox - wired
TV - wired
quick sidenote, when I "diagnosed" the issue last night, I did unplug and replug all wires, as well as disconnected all devices from the modem and it did not appear to have any effect to my PC's connection when plugged in.
PC -
OS: windows 10
Modem: Net gear -
Firmware Version
V1.03.08
PC - wired
2 Phones - wifi
Xbox - wired
TV - wired
