Hello all, I'm attempting my first case mod. And want some opinions with a little problem I've got going. FIRST: If i mount a 120x120x12mm fan behind the mobo mounting plate, should the fan be set to exhaust hot air from mobo to the outside or would it be best by bringing cooler air in to blow on mobo? SECONDLY: I've got two 120's bringing cooler air in from front and this case has two 80mm in back of case for exhaust. There is no room to add a 120mm so i'm kinda stuck with the 80's. Will That be enough to get the air out of the case or create a stagnant air pressure kind of thing. I'm kind of thinking I'm gonna have to run the 80's a little harder to keep up with the 120's. I can add 2-3 80's or 120's at top of case {PSU mounts up top btw} if i need too. Also im not using the area behind the 5.25 bays so i could technically place a 120 there. Just trying to keep the air flowing nice and smooth without placing a ton of fans. I haven't decided if i'm going to make this case my main. Already have that. But proc will be either AM4 or possibly AM5. Just not sure what kinda heat i'm gonna be dealing with. Proc will be air cooled unless i decide i want water. GPU will be a 3060 im thinking. So let me know what you think people. Thanks all!
