Help with advice & opinons
helix090
4
Hi, obviously I am trying to build a new gamin desktop. I've done some research and settled on the parts, but as this is/will be my first time building a desktop I would appreciate any advice about the compatibility and anything you think is important for a newbie.
Motherboard: ASUS P8Z77-V PRO
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131819
CPU: i5-3570K
http://www.newegg.com/Product/Product.aspx?Item=N82E16819116504
Video Card: MSI N660 Ti with GTX 660 Ti
http://www.newegg.com/Product/Product.aspx?Item=N82E16814127696
Case: Thermaltake Chaser Mk-1
http://www.newegg.com/Product/Product.aspx?Item=N82E16811133191
PSU: Corsair HX750
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139010
RAM: Corsair Vengence 4GBx2
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233144
Memory: Kingston HyperX 3K 120GB & WD RE4
http://www.newegg.com/Product/Product.aspx?Item=N82E16820239045
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136697
Much appreciated for comments.
It's a good start but could use some improvement.
For RAM get the low profile version: http://www.newegg.com/Product/Product.aspx?Item=N82E16820233186
Then for GPU the Radeon 7950 is better: http://www.newegg.com/Product/Product.aspx?Item=N82E16814202006
Better SSD: http://www.newegg.com/Product/Product.aspx?Item=N82E16820147136
Better HD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822136891
The case is OK I'd personally go for something from Antec, Corsair, or Fractal Design but that's mostly a personal preference thing.
