A Adrian293 Commendable Jan 11, 2017 2 0 1,510 Jan 11, 2017 #1 I wanted to move my components from my old case to a h440 I have an h100i on the CPU and I wanted to put an h110 on my gpu but I'm not sure if the tubes will reach
Solution K K KeelinTy Jan 11, 2017 They should fit. My friend has a 280mm Kracken or whatever on his gpu with the on the front.
K KeelinTy Reputable Nov 20, 2014 929 0 5,660 Jan 11, 2017 Solution #2 They should fit. My friend has a 280mm Kracken or whatever on his gpu with the on the front. Upvote 0 Downvote Solution
