I need help with airflow on a build i am doing, I have a 360 mm CORSAIR HYDRO Series H150i PRO RGB AIO I have to install in the front, doing an intake and have the fans in top and rear 120 mm fans blow out of the case is this a fair setup for a CORSAIR Obsidian 500D RGB SE Mid-Tower Case?
The computer specs if needed.
- Intel - Core i9-9900K 3.6 GHz 8-Core Processor
- Corsair - H150i PRO 47.3 CFM Liquid CPU Cooler
- MSI - MEG Z390 ACE ATX LGA1151 Motherboard
- Corsair - Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3200 Memory
- Samsung - 970 Evo 500 GB M.2-2280 Solid State Drive
- MSI - GeForce GTX 1080 8 GB Video Card
- Corsair - HX Platinum 750 W 80+ Platinum Certified Fully-Modular ATX Power Supply
- Corsair - LL120RGB LED (Three Fans With Lighting Node PRO) 43.25 CFM 120mm Fans
