Please tell me how good all these are for an all purpose budget pc
any issues, incompatibilities, personal opinion, any suggestions pls help
thanks
Koutech IO-RC521 USB 2.0 Card Reader
http://www.newegg.com/Product/Product.aspx?item=N82E16820162020
HITACHI Deskstar P7K500 500GB 3.5" SATA 3.0Gb/s Internal Hard Drive
http://www.newegg.com/Product/Product.aspx?item=N82E16822145215
Antec earthwatts EA380 380W Continuous Power ATX12V v2.0 80 PLUS Certified Active PFC Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371005
Rosewill R101-P-BK Black Computer Case
http://www.newegg.com/Product/Product.aspx?item=N82E16811147112
Rosewill 18" Serial ATA II cable with metal latch, Model RC-18"-SA2-90-BK, Black
http://www.newegg.com/Product/Product.aspx?item=N82E16812119231
GIGABYTE GA-MA78GM-US2H Micro ATX AMD Motherboard
http://www.newegg.com/Product/Product.aspx?item=N82E16813128379
AMD Athlon II X2 250 3.0GHz Socket AM3 65W Dual-Core Processor
http://www.newegg.com/Product/Product.aspx?item=N82E16819103681
A-DATA G series 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory
http://www.newegg.com/Product/Product.aspx?item=N82E16820211281
Dell - 19" Widescreen Flat-Panel LCD Monitor
http://www.bestbuy.com/site/olspage.jsp?skuId=9366063&type=product&id=1218092173453
and i dont what dvd burner to pick from newegg looking for sata 22x lightscribe optional
can someone recommend something pls
thanks
thanks
thanks
