Help with AMaster
G
Guest
Guest
Archived from groups: alt.games.vga-planets (More info?)
A little over a year ago Piotr and Degi helped me get AMaster going and I
created a couple games with it.
I updated it with v310f and now it crashes when I fire it off
Exiting due to signal SIGSEGV
General Protection fault
Somewhere in the mess of crash junk it also says program=<??unknown??>
I believe if <??UNKNOWN??> is there it means the program crashed inside the
startup code so I know it is not in the amaster config file.
Can anyone here assist or should I just forget using it?
Regards,
Merlyn
Please tell me about your system:
- Your operating system.
- How do you invoke amaster?
- Does the old version of amaster work?
If you want me to compile a new binary, I can try to do so.
Regards, Heiko
"Heiko Schlenker" <hschlen@gmx.de> wrote in message
news:slrncl3uku.4qn.hschlen@humbert.ddns.org...
WindowsXP Pro
From a command promt inside directory where amaster is:
amaster.exe -w d:\plantest\game d:\plantest
Not sure, I will have to dig up the old version, I overlaid it. It did work
previously but I am not sure if it was before I upgraded to XP Pro.
If you think it will help??????????????
Regards,
Merlyn
> WindowsXP Pro
AMaster 3.10f works on my local Windows XP Professional system
(version 5.1.2600, build 2600, no service packs installed).
Are you using programs like virus scanners, personal firewalls,
anti-spyware tools and so on that might disturb other applications?
Regards, Heiko
news:slrncl44ks.2tr.hschlen@humbert.ddns.org...
> > WindowsXP Pro
> Regards, Heiko
Norton and Ad-Aware. Let me turn off Ad-Aware and try it........
Regards,
Merlyn
The stuff from Norton is notorious for it's side-effects ...
Regards, Heiko
news:slrncl48v5.6eo.hschlen@humbert.ddns.org...
> Regards, Heiko
I will try tomorrow with both of them off 🙂
Regards,
Merlyn
