Help With AMD cpu's
Daniel_546
7
I currently have an fx-4300 and I don't know which CPU I should upgrade to. The price for the the fx-8350 and the fx-9590 aren't that much different so I don't know which would be the best. I don't really have a budget but $200 is my max. If anything is wrong about my pc please help me, first time that I built one and have only had it for a couple months (yes I'm already upgrading)
My specs are:
cpu: fx-4300
motherboard: GA-78LMT-S2
graphics card: gtx 1050 ti
8gb of ram
Power supply: 300w (might be 350w so if you could warn me about this situation)
It is not worth it to buy/upgrade in that platform at this point in time as the FX series are already end-of-life with the release of AMD's Ryzen platform.
If you are on a tight budget, consider upgrading/changing platform to a more affordable one that matches (or exceeds) the FX-8350's performance (http://cpu.userbenchmark.com/Compare/Intel-Pentium-G4560-vs-AMD-FX-8350/3892vs1489), but, with future upgradability. For example:
CPU: Intel - Pentium G4560 3.5GHz Dual-Core Processor ($68.99 @ SuperBiiz)
Motherboard: MSI - B250M PRO-VD Micro ATX LGA1151 Motherboard ($61.99 @ SuperBiiz)
Memory: Kingston - FURY 8GB (2 x 4GB)...
Memory: Kingston - FURY 8GB (2 x 4GB) DDR4-2400 Memory ($67.39 @ Amazon)
Total: $198.37
Generated by PCPartPicker 2017-06-16 02:02 EDT-0400
The Pentium G4560 is comparable (if not slightly better) than the FX-8350. With this budget CPU, you get a B250 motherboard that will not restrict you to upgrade to a more powerful CPU (such as the i5-7500 or i7-7700) in the future.
You can still use the other current components (GPU, HDD, PSU) with this build, as the Pentium G4560 is very low-powered (54W TDP) compared to your current FX-4300 (95W) and the AMD CPUs you wish to upgrade to FX-8350 (95W) and FX-9590 (220W!).
