Question Help with an old system to play older games. HDMI issue.
Dec 21, 2024
What it is I’ve just brought a cheap pc for £50
It’s got an i59400
An gtx 1060 6gb
On a msi f310 pro board 16 ram.
I play ps5 and have a m28u monitor that gives you the option to change from 2.1 to 2.0, would leaving it in 2.1 for the gpu give more performance or should I switch to 2.0 for windows 11 ?
Only want it for csgo ?
Any help?
1060 supports Hdmi 2.0, so that's what the monitor will default to.
Hdmi 2.1 supports variable refresh rate so leave this connection for ps5. Your monitor came with both Hdmi and Displayport cables, use Displayport for the graphics card, you'll be able to set refresh rate to optimal and also gsync if want it.
Reactions: Roland Of Gilead
Cheers pal didn’t know DisplayPort would allow me to use gsync ill give that go 🤙
Again thanks for the help.
Reactions: boju
