Archived from groups: microsoft.public.games.ageofkings (
More info?)
Nathan,
When you don't use the router, everything is fine.
Then you use the router and everything is not fine.
Call the router tech support and they'll fix it.
Cheers, Windows XP MVP Shell / User
Jimmy S.
http://mvp.support.microsoft.com
Game FAQs:
;gms]http://support.microsoft.com/default.aspx?scid=FH;[LN];gms
Visit my MSN Zone.com and Gaming Help Site:
http://mvps.org/nibblesnbits
MS Assisted Support:
http://support.microsoft.com/select/?target=assistance
My advice is donated "AS IS" without warranty; nor do I confer any rights.
_________________________________________________________
"Nathan10125" <Nathan10125@discussions.microsoft.com> wrote in message news:708C0112-81D0-4290-94A4-30CD6F6F0B53@microsoft.com...
> this problem is driving me nuts 90% of the time the zone rooms freeze up on
> me i dont care if i have to ip in that much but the rooms freeze. do i need
> to open ports just for the rooms to work? and if so what are they?
> "Jimmy S." wrote:
>> Hi Nathan,
>> Now that you know that the problem is with your router,
>> call their tech support and have them set it up for you.
>> Jimmy S.
>> Game FAQs:
>> "Nathan10125" <Nathan10125@discussions.microsoft.com> wrote in message news:5B1A05C9-4AB7-4DAE-8633-3E9E0F83AFD8@microsoft.com...
>> > ok it works fine if i do that but i have 4 other computers that need the
>> > internet too.
>> > "Jimmy S." wrote:
>> >> Okay, keep us posted with the results.
>> >> Jimmy S.
>> >> Game FAQs:
>> >> news:68A8D05E-D3CB-4CD7-AECE-B8DA57045C6A@microsoft.com...
>> >> | dont know i have not tried but im sure it will. if i ip it works fine but not
>> >> | when i try to use the zone so i think its the zone ports that need to be
>> >> | opened but im set as dmz
>> >> | "Jimmy S." wrote:
>> >> | > Hi Nathan,
>> >> | > Does the game work when you connect without the router?
>> >> | > Jimmy S.
>> >> | > Game FAQs:
>> >> news:68268F76-8815-4A9E-BFB6-798A4FE7728F@microsoft.com...
>> >> | > | ok i called them up and they helped me do somthing but it did not fix the
>> >> | > | problem
>> >> | > | "Jimmy S." wrote:
>> >> | > | > I read your first post, but suggested you have the router's tech
>> >> | > | > support assist you with either DMZ or port opening as not all
>> >> | > | > people who purchase routers realise tech support is included.
>> >> | > | > Cheers,
>> >> | > | > Jimmy.
>> >> | > news:95FDA7C9-88A6-4D23-A56D-63BC026CE1A0@microsoft.com...
>> >> | > | > > maybe you did not read my first post i am set as a dmz. also i just found out
>> >> | > | > > last night that some times it works and i dont have to ip in other times it
>> >> | > | > > wont same with the game rooms freezing up. i did reinstall the zone files
>> >> | > | > > maybe that will fix some of the problems i can pray anyways.
>> >> | > | > > "Jimmy S." wrote:
>> >> | > | > >> Hi Nathan,
>> >> | > news:9A6EBBCC-81FE-465E-9DD3-5560EAED9A78@microsoft.com...
>> >> | > | > >> > hello. ok first off my zf is not comming up. and i join a game room and it
>> >> | > | > >> > just freezes up. the game is age of empires2 and if i join custom game rooms
>> >> | > | > >> > it freezes up i cant even pick what game before it freezes other times it
>> >> | > | > >> > works fine. also when i do get into a game everyone below me has 30 ping. the
>> >> | > | > >> > only thing i can think of is i just got a new router but i also set myself as
>> >> | > | > >> > DMZ so i dont know. i can ip in and that works fine but thats getting
>> >> | > | > >> > anoying.
>> >> | > | > >> Call the tech support for that unit, and ask them to either setup a "DMZ"
>> >> | > | > >> (De-Militarized Zone which means the firewall is disabled) to bypass the
>> >> | > | > >> built-in firewall, or open the necessary ports in the equipment with you.
>> >> | > | > >> Here's the List of all Ports used by Zone
>> >> | > | > >> and DX Games:
http://mvps.org/nibblesnbits/PortRoute.html#ports
>> >> | > | > >> To setup your router yourself visit: www.portforward.com/routers.htm
>> >> | > | > >> Jimmy S.
>> >> | > | > >> Game FAQs:
>> >> | > | > >> Visit my Zone.com / Gaming Helpsite:
http://nibblesnbits.tk or Call / Contact
>> >> | > | > >> MS Support at:
http://support.microsoft.com/default.aspx?scid=sz;en-us;top
