Hello everyone,
I just assembled my first PC over the last two days and nearly everything is working great.
As the title says, I am using an ASUS Prime X570-P motherboard that is housed in a Lian Li Lancool Mesh II case. I've plugged my CPU fan into the CPU_FAN and the three case fans into the CHA_FAN 1-3 connectors.
It was suggested that I should add some exhaust fans and another intake fan to improve cooling. I purchased a three pack of Thermaltake Pure 12 ARGB fans and installed them into the case.
The problem is that the only place left to insert the plug is in the AIO_PUMP connector which forces the fans to run at 100%.
I've gone into BIOS and attempted to change the settings for the AIO_PUMP, but there is no option to do so. All that can be done is switch between PWM and DC, which doesn't appear to change anything.
Is there anyway for me to adjust this fan speed setting?
I appreciate you taking the time to read this post and any suggestions you might have.
Thanks
Thanks
