Help with audio driver
8layers
28
I recently factory reset my computer. I have a Hewlett-Packard p7-1534 on windows 10. The audio will not work and I cannot find the right drivers for my computer. Any help is welcome. Thanks
Actually it fixed the problem where it was stuck on mute and worked for a little bit but now it won't play and sound.
Try the following from http://answers.microsoft.com/en-us/insider/forum/insider_wintp-insider_devices/idt-high-definition-audio-codec-not-working-on/570a5038-e48e-43f3-af75-95da61447c87?page=41
I had a same problem on HP Envy 23 1080jp All in one desktop PC.
I can solved as following.
1. Select IDT High Definition Audio CODEC on Device Manager.
2. Select Driver tab.
3. Click Update Driver... button.
4. Select -> Browse my computer for driver software.
5. Select -> Let me pickup a list of device drivers on my computer.
6. Select High Definition Audio Device (NotIDT High Def... this is important.) and click Next.
Appears Warning message, but reply Yes.
7. ! Windows has successfully update your driver software.
Key is step 6.
Thanks
Got it now it works for sure lol
