Help with Barton 2500
mark204
43
Hey,
I can't get my barton 2500 to over clock, my system won't boot after I change the FSB to 200 in the bios. My specs:
Chip: Barton 2500
Bios: 1007
Board: Asus A7N8X-E Deluxe
Memory: 2x256MB Corsair 32MX8 PC-3200
PowerSupply: Antec True 480
ChipTemp: 40 Deg C +/- 1
Not being able to overclock new system: PRICELESS
I've even tried stepping up the voltage in .25 increments to 1.7 - didnt work.
Does anyone know of any other settings that need or can be done with this board to make it over clock? Is there a way I can step the FSB in smaller increments?
I really appreciate any help.
Mark
if you're gonna be a bear, be a GRIZZLY!!
Yeah, you'll wanna up that FSB in increments. I don't have your board so personally can't give specific instructions. Go here (nForcersHQ) to asus section. This link takes you to the tutorial for OCing your board <A HREF="http://www.nforcershq.com/forum/viewtopic.php?t=15496" target="_new">http://www.nforcershq.com/forum/viewtopic.php?t=15496</A>
Good Luck
XP 2000+
MSI KT3 ULTRA-2 KT333
Maxtor 60GB ATA 133 7200RPM
512MB PC2700
9600 Pro
Win98SE
Also, you might want to check the revision # on the board (between the Agp and the Pci slot). If you have rev 1.xx then you might want to flash back to the 1004 bios. If you have rev 2.xx then you can stay at 1007. It has been shown that the difference in the bios can affect your ability to overclock. The best source of info for this board is nforcershq.com.
A7n8x dlx 1004 Uber Agressive settings
2500Barton (Bastards locked it) Radeon 9200
WD 60g @7200w 8mg Cache Crucial 2700 2x 256
AMD ME??? Yeah they did me alright.
