My current specs are as follows
a78-e35 msi motherboard
AMD a10-6800k / Radeon 8670D
single stick of 8gb ram
500w power supply
Since I found out that to get the most out of the intergrated gfx you need dual channel 1866mhz ram I decided getting a gfx card is the best solution. Wondering if the evga nvidia 750ti performs noticeably better than these intergrated gfx. Can I run ArcheAge on max smoothly with it? and will I need to change any other hardware to make the most out of the 750ti
Appreciate the help, thanks.
500w power supply
