HELP with Blue screen of deaths!!!!!!!!
yetyhunter
299
It appears randomly whne I boot up vista. Stop:0x0000008e error. I have an Asus p5n-d E8400 2gb 800mhz kingston ram, 8800 GTS 512. I have reinstalled all the latest drivers for mobo ,sound and GPU in safe mod and I still get this at startup after the vista loading screen.
crash27
35
blue screen is almost always a ram problem. try running a ram testing program of some kind. there is one built into vista.
night_wolf_in
702
first, if you want help with error codes. then post the whole thing. Stop:0x0000008e error is not the full thing.
just get the full thing and search google for it.
example of full error code, "stop: 0x0000008E (0XC0000005, 0X81D93E9C, 0XB06FBC50, 0X00000000)"
with full error, you might get easier location of different people having same problem, thus finding a solution.
try using memtest84+ to c if there is any ram issues or not.
yetyhunter
299
I veryfied the memory with vista memory checker.Here are the details
BCCode: 1000008e
BCP1: C0000005
BCP2: 81E38E65
BCP3: 8A793B4C
BCP4: 00000000
OS Version: 6_0_6001
Service Pack: 1_0
Product: 768_1
I copied these from the vista problem reports
yetyhunter
299
I ran the mem test 2 TIMES and I found NO ERRORS.
Maybe it's adriver problem or something wrong with the bios ,because I OC'ed my cpu to 3.6 ghz and I changed some others settings. I should try with default settings.
yetyhunter
299
I did: ram 1.89(default 1.8),cpu1.18750 OC'ed to 3.6(STABLE),HT to 1.44,NB 1.40,SB 1.60.
I tryed to boot up with default settings but still got the error.
flyin15sec
985
14
I have the same board. I can tell you this, at a 1:1 cpu/mem ratio. The NB boot strap for my board and processor(E8200) is not stable at all. It will pass Prime95 Small FTT, but in Blend it will fail.
My suggestion,
1. Up your voltage a bit more to 1.225v in BIOS --> Actual with CPUz will read about 1.185v, Vdroop on this board is .04v
2. Go to 3.7Ghz(RatedFSB 1644) , or downclock to 3.5Ghz(RatedFSB 1555)
3. Keep your memory unlinked, and set it close to 800Mhz or below.
If memory is testing fine, then there's a good chance you're just in an FSB hole. Do the 3 things I suggest, that should stablize things.
yetyhunter
299
I just ran memtest 86 + and found NO ERRORS . Here is the report:
WALL TIME Cached rsvd mem Cache ECC Test PASS ERRORS
12:35:27 2047 52 on off Std 20 0
This means that the BSOD is not caused by the memory.Maybe it's because of bad timings settings.Default timings are 6-6-6-18 I think and I set them to 5-5-5-15 and increased the voltage to 1.890 (default 1.8)
Or maybe it's a driver problem . I have all the latest drivers Installed.
Similar threads
