Question help with build please
Feb 27, 2020
4
I was told to use MSI arsenal gaming motherboard? Build 1 is what I originally had and build 2 is what was suggested. Computer is 8 years old, video card 590 is what I currently have.
Build 1:
PCPartPicker Part List
Type|Item|Price
CPU | AMD Ryzen 5 3600 3.6 GHz 6-Core Processor | $174.99 @ B&H
Motherboard | MSI MPG X570 GAMING PLUS ATX AM4 Motherboard | $159.34 @ Amazon
Memory | Corsair Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3000 Memory | $92.99 @ Amazon
Video Card | Sapphire Radeon RX 590 8 GB PULSE Video Card | $276.86 @ Amazon
| Prices include shipping, taxes, rebates, and discounts |
| Total | $704.18
| Generated by PCPartPicker 2020-02-27 06:30 EST-0500 |
Or this build
Build 2:
Type|Item|Price
Motherboard | ASRock B450 Pro4 ATX AM4 Motherboard | $89.99 @ Amazon
Memory | GeIL EVO POTENZA 16 GB (2 x 8 GB) DDR4-3000 Memory | $64.99 @ Newegg
| Total | $606.83
| Generated by PCPartPicker 2020-02-27 06:32 EST-0500 |
4745454b
Video card is over priced for what you get. It's an overclocked 580, which is more like $200. At nearly $300 you should be looking at something else. A problem you can have with the board you picked is the 3xxx chips need a bios update to run on B450 boards. Getting a 5xx board removes that worry. Build two can work. But I'd get a different GPU no matter what. (although you said you already have it?)
Feb 27, 2020
4
Yeah already have the card, paid less than 200$ just stuck it in there to go with build. The first build is what I picked, the second is what was suggested. I wasnt sure if it was just the price point or what was better.
WildCard999
I'd get this instead if possible, the motherboard ships with Ryzen 3600 support, easy to navigate BIOS & has Wifi/BT. You'll also want 3200mhz memory as Ryzen performs better with fast memory.
CPU: AMD Ryzen 5 3600 3.6 GHz 6-Core Processor ($174.99 @ B&H)
Motherboard: ASRock B450M/AC Micro ATX AM4 Motherboard ($84.99 @ Amazon)
Memory: Patriot Viper 4 Blackout 16 GB (2 x 8 GB) DDR4-3200 Memory ($72.98 @ Amazon)
Total: $332.96
Generated by PCPartPicker 2020-02-27 08:18 EST-0500
Reactions: logainofhades
Another good option, for you to consider.
Motherboard: MSI B450 TOMAHAWK MAX ATX AM4 Motherboard ($114.89 @ B&H)
Memory: G.Skill Ripjaws V 16 GB (2 x 8 GB) DDR4-3600 Memory ($82.99 @ Newegg)
Total: $372.87
Generated by PCPartPicker 2020-02-27 13:27 EST-0500
I would suggest this build as well. That motherboard is a great price/performance and I do feel that 3600mhz is a good pick for 3rd Gen Ryzen.
