Question Help with build upgrade
Jing__
Commendable
Dec 30, 2016
12
PCPartPicker part list: https://pcpartpicker.com/list/xR9G4q
Price breakdown by merchant: https://pcpartpicker.com/list/xR9G4q/by_merchant/
CPU: Intel - Core i7-9700K 3.6 GHz 8-Core Processor ($419.99 @ Newegg)
CPU Cooler: Corsair - H150i PRO 47.3 CFM Liquid CPU Cooler ($146.89 @ OutletPC)
Motherboard: Gigabyte - Z390 AORUS ELITE ATX LGA1151 Motherboard ($179.99 @ Amazon)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3200 Memory ($119.99 @ Amazon)
Storage: Crucial - MX100 256 GB 2.5" Solid State Drive ($150.00)
Storage: Samsung - 860 Evo 500 GB 2.5" Solid State Drive ($77.99 @ Amazon)
Storage: Western Digital - BLACK SERIES 1 TB 3.5" 7200RPM Internal Hard Drive ($64.00 @ B&H)
Video Card: Gigabyte - GeForce GTX 1080 Ti 11 GB AORUS Xtreme Edition 11G Video Card ($783.00)
Case: Lian-Li - PC-O11 Dynamic (White) ATX Full Tower Case ($144.98 @ Newegg Business)
Power Supply: Corsair - 750 W 80+ Platinum Certified Fully-Modular ATX Power Supply ($147.00 @ OutletPC)
Operating System: Microsoft - Windows 10 Home OEM 64-bit ($98.89 @ OutletPC)
Total: $2332.72
I will be re-using the GPU, PSU and storage from my old build. The rest (CPU,Case,RAM,MOBO,Cooler) will be bought. Any feedback or issues with the build or recommendations would be greatly appreciated!
My old build could not run a lot of modern games at steady frame rates (FFXV, KCD,Apex Legends) because my CPU was bottlenecking my GPU. I would also like to stream gameplay on twitch.
I am currently playing on 1440p, with a 144Hz monitor.
I live in Singapore and was planning to buy my parts online through Newegg or something similar because the cost of the parts locally is far greater than buying from newegg. I was wondering how would warranty of my parts work if I didn't buy the parts locally? Any help or feedback would be appreciated thanks!
computerjoe314
Upstanding
Jan 2, 2019
318
16
315
5
Overall it looks great.
You might want to get a Ryzen 7 2700X instead of a 9700K, but that really depends on what you'll be doing with it. Also, if you'll want to upgrade, you'll probably want to go with Ryzen.
jmnorthern
Commendable
Jun 29, 2016
31
6
Save $214
Add: Samsung 970 EVO 1TB @ $218 on Amazon.
Power Supply: Corsair - 750 W 80+ Gold Certified Fully-Modular ATX Power Supply ($109.99 @ Amazon)
Save $37.01
rookieGamer
112
seem like a solid build.
i would suggest you wait till end of this year, if you can as new 10nm and 7nm chips will be launched.
you can also save on case.. i personally would go for the cheapest case i could find with good airflow and spend that money on Nvme ssd not sata ssd.
you can save on Ram as well, and go with 3000mhz, its an intel build.
for warranty, i think that is given from the manufacturing company not new egg, you can ring up your local service center of gigabyte and intel and check with them.
Jing__
Commendable
Dec 30, 2016
12
Save $214
Save $37.01
I already have these from my current build and will just be transferring them to the new one.
I plan on streaming and playing games at 1440p at high refresh rates. Will the 2700x be better than 9700k for this?
