Help with build
footballmontana
74
First thanks in advance for your help. I built a htpc with a rvz01. I used a Asrock am1h-itx, 5350 apu, ssd and uj265 blu-ray drive. My problem I can't hook up the drive. The board came with a sata power cable, so I have my ssd hooked up to that and other sata power doesn't fit the blu-ray drive. I've checked on Amazon and found Silverstone Tek CP10 sata to sata adapter. My question is what do I need to hook up the molex on CP10 to other end of my sata power cable that came with my mobo.
Thanks
