Question Help with building a new system
JAMES PHILLIPS
Hello everyone
I’m looking to replacing my old computer to something new.
I’ve never built a computer so this is all new. My main use for the build will be to stream 4K and hope 8k videos. Also some VR and online drone racing.
My budget is 3000.00 for the build excluding the monitor keyboard and mouse.
So if you guys can help me piece together the best build possible in this 3k budget I would greatly appreciate it. If we go over some I’m not worried but I really don’t want to get into a 4K territory on spending.
Thanks in advance
I'd install the rad on the top. Take note of the vertical graphics card mount
PCPartPicker Part List
CPU: Intel - Core i9-9900K 3.6 GHz 8-Core Processor ($484.99 @ Amazon)
CPU Cooler: Corsair - H100i RGB PLATINUM 75 CFM Liquid CPU Cooler ($129.99 @ Corsair)
Motherboard: ASRock - Z390 Taichi ATX LGA1151 Motherboard ($209.99 @ Amazon)
Memory: Corsair - Vengeance RGB Pro 16 GB (2 x 8 GB) DDR4-3600 Memory ($149.99 @ Amazon)
Storage: Samsung - 970 Evo 2 TB M.2-2280 Solid State Drive ($499.00 @ Amazon)
Video Card: Asus - GeForce RTX 2080 Ti 11 GB ROG Strix Gaming OC Video Card ($1269.99 @ Newegg)
Case: Corsair - Crystal 570X ATX Mid Tower Case ($109.99 @ Newegg Business)
Power Supply: Corsair - TXM Gold 850 W 80+ Gold Certified Semi-modular ATX Power Supply ($85.88 @ OutletPC)
Case Fan: Corsair - SP120 RGB High Performance 52 CFM 120 mm Fan ($18.26 @ OutletPC)
Custom: MasterAccessory Vertical Display Graphics Card Holder Kit Including ($49.85 @ Walmart)
Total: $3007.93
Generated by PCPartPicker 2019-06-12 15:03 EDT-0400
Reactions: ocer9999
JAMES PHILLIPS
I'd install the rad on the top. Take note of the vertical graphics card mound
Total: $3007.93
Thank you sir I’ll look into what you’ve suggested
jeremyj_83
Commendable
Aug 23, 2017
1,093
97
1,590
91
CPU: AMD - Ryzen 7 2700X 3.7 GHz 8-Core Processor ($279.99 @ Amazon)
CPU Cooler: Noctua - NH-D15 SE-AM4 82.52 CFM CPU Cooler ($89.90 @ Amazon)
Motherboard: Gigabyte - X470 AORUS GAMING 7 WIFI ATX AM4 Motherboard ($229.99 @ Amazon)
Memory: G.Skill - Ripjaws V Series 32 GB (2 x 16 GB) DDR4-3200 Memory ($249.99 @ Newegg)
Storage: Western Digital - Blue 500 GB 2.5" Solid State Drive ($59.99 @ Amazon)
Storage: HP - EX950 2 TB M.2-2280 Solid State Drive ($294.99 @ Amazon)
Storage: Hitachi - Ultrastar 7K4000 4 TB 3.5" 7200RPM Internal Hard Drive ($83.99 @ Amazon)
Video Card: MSI - GeForce RTX 2080 Ti 11 GB SEA HAWK X Video Card ($1159.99 @ Amazon)
Case: Fractal Design - Define S2 Vision ATX Mid Tower Case ($251.98 @ Newegg)
Power Supply: SeaSonic - PRIME Ultra Titanium 850 W 80+ Titanium Certified Fully Modular ATX Power Supply ($210.43 @ Amazon)
Total: $2911.24
Generated by PCPartPicker 2019-06-12 15:28 EDT-0400
Alternative build using AMD.
jeremyj_83
Commendable
Aug 23, 2017
1,093
97
1,590
91
CPU: AMD - Threadripper 2950X 3.5 GHz 16-Core Processor ($799.99 @ Amazon)
CPU Cooler: Noctua - NH-U14S TR4-SP3 82.52 CFM CPU Cooler ($79.90 @ Amazon)
Motherboard: Gigabyte - X399 AORUS PRO ATX TR4 Motherboard ($279.99 @ Amazon)
Memory: G.Skill - Ripjaws V Series 32 GB (4 x 8 GB) DDR4-3000 Memory ($149.99 @ Newegg)
Storage: Intel - 660p Series 2 TB M.2-2280 Solid State Drive ($194.99 @ Newegg)
Case: Fractal Design - S2 ATX Mid Tower Case ($144.98 @ Newegg Business)
Power Supply: SeaSonic - FOCUS Plus Gold 850 W 80+ Gold Certified Fully Modular ATX Power Supply ($119.99 @ Amazon)
Total: $2989.81
Generated by PCPartPicker 2019-06-12 15:35 EDT-0400
Threadripper build.
Total: $2989.81
Threadripper build.
No it’s not a rush build just gonna start buying parts here and there.
Instead of purchasing parts here and there, my advice is to just take that money and save it. The only reason I say that is because by the time you're ready to buy, there may be something better out there that might cause you to think "If only I waited to purchase this component". I'm only telling you this because i've been down that road. As far as im concerned, it's your money and you can spend it any way you deem necessary however with a $3000 budget, going anything other than an i9 9900k/z390/RX2080ti would be a huge mistake. That's the best hardware currently on the market right now. Yes Ryzen third gen is expected to be on par with intel and will be releasing in a month, however you don't know the problems/implications what will follow because of how new the hardware is. Having to put a chipset fan on x570 is a big red flag to me and we don't know the performance/thermals yet. If you are spending 3k on a build, because that's a higher end budget, pull the trigger on he i9 system.
View: https://www.youtube.com/watch?v=jkrQP7Ynzlk&t=21s
Reactions: JAMES PHILLIPS
cats_Paw
3,194
139
Dont buy now if you can wait.
First, 4K streaming? You mean streaming into a platform like twitch or youtube? To save it onto a PC? 4K requires massive bandwidth... and that is on 60 Hz. I ask because 4K is really gonna limit your viewer count if its for something like Twitch, not to mention there is a limit for upload on that platform. And if you are streaming to a Drive to save it, you better have some fast drives for it.
(https://www.quora.com/What-is-the-size-of-a-file-with-one-hour-of-4k-video )
If you dont know much about streaming, that is another thing you need to consider.
If we are talking gaming only, Intel CPUs right now are still better, but for heavy workloads I would wait and go for a 12 or 16 core AMD CPU.
NOW pay attention cus this is IMPORTANT: Cooling any cpu that will do so much work is hard and you should inform yourself ALOT before you make a buy.
Either you will have a monster Air cooler with crazy airflow OR you will have to go with a custom watercooling setup (All in one watercoolers are not something I would ever recommend.).
