Help with building a pc in the NZXT S340 case
RhinoTV
331
Hello
I’m really into pc’s and wanted to build one but was always afraid to do it with my own system. I decided to buy my dream case and I’m going to try and transfer everything over into it. I have a feeling I know how to do it but my only concern is connecting the front panel Connects to the mobo.
I’ve a ASU’s z97k mobo.
Thanks so much to anyone that helps!
Just take your time and use the Asus manual to make sure your connecting everything correctly.
https://www.asus.com/us/Motherboards/Z97KCSM/HelpDesk_Manual/
To answer your question the front panel connections are typically on the bottom of the board, the text will be pretty small but they are labeled. The front USB 3.0 connection is on the bottom-right of the RAM slots.
If you run into any issues just post back here and well help you out the best we can.
Everything worked fine and looks really neat ! Only 2 problems is the fan on the top (I got 2 one at the back and one on top) there connected to something that game with the case. Think its so fan splitter or something. The fan on the top is really fast (prob max speed and loud) while the one at the back is isnt really fast and isnt pushing nearly as much air out than the other.
Also when I plug my phone into the usb the left usb slot doesn't work but the right does but as soon as i put my phone down on the table ( ie not holding it up) it starts to say charging and then not charging charging then not charging ect...
Any fixes ??
