Help with building my first gaming computer
pielovinpie
4
I'm a complete noob at picking computer components and I need help with choosing parts that go with the Intel i3570K and the GeForce GTX 770.
If possible, I'd like to keep it at maximum $1000.
I already have my copy of Windows, as well as a monitor. I also am set with a keyboard an mouse, so all I really need are the components.
Hiii
check this
http://pcpartpicker.com/b/DKH
CPU Intel Core i5-4670K 3.4GHz Quad-Core $239.99 Newegg
CPU Cooler
Cooler Master Hyper 212 EVO 82.9 CFM
Sleeve Bearing $29.98 Outlet PC
Motherboard Gigabyte GA-H87-D3H ATX LGA1150 $104.99 Newegg
Memory
Corsair Vengeance 8GB (2 x 4GB)
DDR3-1600 $71.37 Amazon
Storage Samsung 840 Pro Series 128GB 2.5" SSD $129.98 Outlet PC
Western Digital Caviar Blue 500GB 3.5"
7200RPM $54.49 Outlet PC
Video Card EVGA GeForce GTX 760 2GB $259.99 Amazon
Case Cooler Master Elite 370 ATX Mid Tower $33.78 NCIX US
Power Supply SeaSonic 620W ATX12V / EPS12V $66.98 Newegg
Optical Drive
Asus DRW-24B1ST/BLK/B/AS DVD/CD
Writer $24.98 Newegg
Total: $1005.53
hey if there is any microcenter then you can pick your cpu from there you will get it @ $199.99 & with saved money get better cpu vooler like h60. If you plan to oc upto from 4.1ghz.
I hope it helps.
Thank you.
Thank you for the build. 🙂
I'll look in to it and read up some stuff.
EDIT: I don't plan on overclocking, so I'll stick with the 3570K.
Hey
its not mean only 4670k oc. Every "K" cpu you can oc. 3570k also can be oc.
I chose haswell because its new chipset and faster around 10% than ivy bridge and may be some future proof bcs next upcoming gen BROADWELL also may come in 1150 socket.
If you want to stick with ivy bridge than its your choice. But you can go with Haswell for everything better you will just need a better cpu cooler IF you plan to oc.
I hope it helps.
Thank you.
Oh I didn't know that. I'll look at Haswell. Thanks. :)
No problem.
its my pleasure.
i gave you a build. you may check this.
i hope it helps.
thank you.
For gaming rig
1. Dont need 1866 mhz memory. 1600mhz is enough for everything.
2. Crossfire means always in problems. So dont go with amd gpu if plan one more gpu to add. Nvidia is best for sli and 760is newest chip. Its performance, cooling, everything is upgraded. So it is best option.
3. Cx series psu dont support haswell. So better to go with haswell certified psu like i chose.
4. Ssd samsung 840 pro is best and hdd he can upgrade one more to 1tb or as his wish in one month. Present time dont need much storage. 500gb is enough for right now.
I hope it helps.
Thank you.
